Author [NL] [FR] [ES] [DE] [SE] [IT] [NO] [MY] Topic: Wax or Lube for the chain  (Read 2765 times)
  • Bike: F750GS 2020
Re: Wax or Lube for the chain
« Reply #10 on: October 13, 2020, 10:32:35 PM »
While in no way attempting to hijack this thread, I have a related question?
When your new bike arrives (or if you watch the BMW factory tours) you see that the chains as they come out of the factory appear to have a light white grease applied (I'm guessing it's LM grease?). Is this indicative of what BMW tend to recommend for lubing the chain or is this a case of a manufacturer (not singling out BMW here) just using the most economical grease they can find (just to get you started) and it's not necessarily what they would recommend you use?
A quick scan of the user manual (for the F750GS) just points you to use the chain cleaner and lubricant as supplied by your local BMW dealer. It does not specify a specific brand or recommended specification for the lubricant.
« Last Edit: October 13, 2020, 10:36:17 PM by B0M0A0K »
« Reply #11 on: October 14, 2020, 01:21:50 AM »
*Originally Posted by B0M0A0K [+]
The white ("Whatever it is") grease is a mess waiting to happen. At least take a rag and get as much off as possible because if not it will be all over the bike and rims.
Offline doebag
« Reply #12 on: October 14, 2020, 07:33:34 AM »
*Originally Posted by SnoDrtRider [+]
That wasn't my experience. The white grease stuck like the proverbial and I had no fling on to the rear of the bike or number plate. At the recent service, the dealer cleaned/lubed/adjusted the chain and used 'normal' lube. No white grease in evidence.
Offline doebag
« Reply #13 on: October 14, 2020, 08:22:22 AM »
The BMW chain lube has no specification on the can at all. You'd probably need to search the part number for more information. However I just sprayed a small amount onto a piece of board. It comes out as a very 'thin' liquid, the carrier then evaporates very quickly to leave a tacky residue. I have yet to use it on the chain.
  • Bike: F750GS 2020
« Reply #14 on: October 14, 2020, 09:07:20 AM »
I think this is all why I resorted to EP90 for a good long while. I was finding that many of these chain lubes would just cause the chain to gather dirt and grit (the latter surely going to reduce the life of your chain) - at least with the EP90 it would throw off the garbage. But as I mentioned, it went everywhere.
Where I live (East Coast of Scotland) the council tends to use a very aggressive road salt over the Winter and it absolutely killed the chain and surrounding metalwork.
« Last Edit: October 14, 2020, 09:09:06 AM by B0M0A0K »
« Reply #15 on: October 26, 2020, 03:36:43 AM »
Jeebus how many concurrent threads on this do we really need??  :435:
https://www.850gs.com/index.php/topic,910.msg6551.html#msg6551
« Reply #16 on: October 26, 2020, 03:50:31 AM »
It's a type of chain lube that many shops use during servicing as it is their preferred lube for servicing, lasts a while but is very messy to apply if not performed carefully.
Offline Oldum
  • Town / City: Bristol
« Reply #17 on: September 09, 2021, 04:23:00 PM »
A late response on this topic but having spent half a day cleaning 2 years worth of wax, oil, lube off my chain and sprockets I found this “research” useful.  Still no holy grail… you either get mess or rust!
« Reply #18 on: September 09, 2021, 11:33:25 PM »
I just cleaned our chains today... I do a cleaning Spring and Fall... Spray with WD-40 and let them soak then brush them with a poly bristle brush such as a tooth brush. Wipe them with a rag then use Simple Green to brush them down again. Hose off and blow dry with air. A short ride to get them warm and apply new Chain Lube of choice... Mine is BelRay "Super Clean" allow to sit overnight or at least a few hours before use.
« Last Edit: September 09, 2021, 11:33:57 PM by SnoDrtRider »
