Author [NL] [FR] [ES] [DE] [SE] [IT] [NO] [MY] Topic: Suspension modification  (Read 4397 times)
Offline KSD
  • Town / City: Toruń
Re: Suspension modification
« Reply #10 on: June 08, 2020, 06:36:35 PM »
In my opinion, it's best to just turn off ABS and traction control manually. I don't use this modes and I don't need them. Entering the offroad, I change the settings myself.
« Reply #11 on: June 08, 2020, 07:05:49 PM »
*Originally Posted by talh [+]
I thought so too, and nearly crashed because the ABS wouldn't let me stop in Enduro mode. It didn't shut off ABS for me.
I know Enduro PRO let's you shut everything down but I think regular Enduro just eases the rear ABS so you can slide the rear into a turn.
Offline talh
  • Town / City: San Jose, CA
« Reply #12 on: June 08, 2020, 08:52:53 PM »
I don't have Enduro Pro on my 750GS... do you know of a way to enable it?
« Reply #13 on: June 08, 2020, 09:15:29 PM »
There should be a pigtail under your seat with a black cap on it a dongle gets plugged in in place of the cap. Some people say you can use a jumper but I'm not taking chances on smoking the ECU...
Page 119 of the manual starts the instructions for Riding Mode PRO and Enduro Mode PRO.
« Last Edit: June 08, 2020, 09:20:46 PM by SnoDrtRider »
Offline talh
« Reply #14 on: June 08, 2020, 09:53:11 PM »
Doesn't seem to exist on my 2020 F750GS...
« Reply #15 on: June 08, 2020, 10:00:14 PM »
What the pigtail??? I could see it not being ordered in which case you would no have received the "Encoding Plug" but it doesn't make since that the wire harness would be different...
Offline talh
« Reply #16 on: June 08, 2020, 10:05:47 PM »
No pigtail, no plug :)
Offline 999pablo
  • Bike: F750gs
  • Town / City: Thousand Oaks
« Reply #17 on: June 09, 2020, 06:10:32 AM »
My 2019 750 has the plug but the dongle won’t work on it because the bike does not have enduro pro like the 850. I just turn off the abs manually. That may not be an option for the 2020 models. Abdullah. I have the hyper pro springs and they lower the bike 30mm on ESA equipped bikes. It also improves the suspension (way less dive in hard braking). The springs are progressive and ultra soft for the first 30mm of travel. Your body weight will be enough to do that first 30mm then the suspension gets progressively stiffer. It was a good improvement. The lower seat will get you another inch. Also your bike is lowest in rider only mode. If you go to rider plus luggage mode the rear raises about one inch. Good luck.
F750gs
Offline Newguy
  • Bike: 850 GS
  • Town / City: Bellingham
« Reply #18 on: June 09, 2020, 02:09:36 PM »
ABS is not fully shut off in Enduro, that is not to say you can't shut it off manually yourself but the ABS will still keep track of the front tire.
Enduro Pro permits some variability in custom settings.
Offline netaron
  • Town / City: Scottsdale, AZ
« Reply #19 on: July 16, 2020, 04:37:18 PM »
I find the rear sliding control in enduro-pro (maybe available in enduro mode as well??) useful as it can be adjusted progressively; these big bikes can get a bit unwieldy when loose on dirt.
« Last Edit: July 16, 2020, 04:38:14 PM by netaron »
