Author [NL] [FR] [ES] [DE] [SE] [IT] [NO] [MY] Topic: Tioli mods  (Read 8063 times)
Online LFC09
  • Town / City: Sunshine Coast
Re: Tioli mods
« Reply #110 on: July 25, 2020, 11:27:29 AM »
Ill get some deets and pic tmrw. Over in the shed.
Offline Tioli
  • Bike: F750GS HP Special
  • Town / City: Tasmania
Re: Tioli mods
« Reply #111 on: July 25, 2020, 12:28:28 PM »
Love a shed anything is possible
Hindsight is a terrible way to learn Id rather be gifted
Online SnoDrtRider
Re: Tioli mods
« Reply #112 on: July 25, 2020, 12:35:43 PM »
 I got this off Amazon and used it to line the inside of the side panel on a Husqvarna I restored...
https://www.amazon.com/Barrera-adhesiva-respaldo-Thermo-Tec-13575-12/dp/B00029KC2K/ref=sr_1_3?crid=2JU329CBD3ZV4&dchild=1&keywords=self+adhesive+heat+shield&qid=1595677049&sprefix=Self+Adheasive+heat%2Caps%2C170&sr=8-3
Since you already made an inner pan for the bag I would just pop rivet an aluminum plate to the bottom of the bag through the inner pan then apply the Thermo-Tec to that.
« Last Edit: July 25, 2020, 12:42:18 PM by SnoDrtRider »
Offline Tioli
Re: Tioli mods
« Reply #113 on: July 25, 2020, 01:10:02 PM »
Thanks SnoDrtRider I have seen that stuff before as I guess anyone who's been around bikes long enough has. What I dont like about that for this application is the panniers are flexible and will flex a little a lot. Im thinking over time dust will work its way in to the adhesive as it flexes and once in a little it just keeps working in.
Actually now that I think about it Im still favouring separating the hot and cold air however if it turns out the checker plate is getting to hot and radiating heat then a layer of that or similar on the smooth side of the plate would be the answer.
Offline Tioli
Re: Tioli mods
« Reply #114 on: July 31, 2020, 11:55:57 AM »
When you don't have it you want it need it  when you have it you don't feel as if you need it.
Offline Tioli
Re: Tioli mods
« Reply #115 on: July 31, 2020, 12:30:33 PM »
My smart relay turned up looks promising nice BMW box
Looks a little exposed without a backing
It has to fit on and around the mirror stalk like this
A little tapped plate like this to hold the switch on
Offline Tioli
Re: Tioli mods
« Reply #116 on: July 31, 2020, 01:05:01 PM »
When I do it up it tightens on like this in the wrong spot
Bend the tab out to move the top of the switch in
Now it does up in the right place but I didn't like how the metal tab cracked as it bent it that metal is  hard and inflexible. I'm going to proceed as if it's going to hold but there will always be dought. If it lets go a few cable ties or tape will get me home.
The next problem is what to do about the exposed board. As a coating I'm hoping this lanolin spray will protect it when it drys.
Then I discover with the fixing tab bent in the plastic protrudes beyond the mirror stem mount. Has to be dremilled down to make it flush
To cover in the back and give it some protection I cut some soft rubber hose and poke it in
It looks the part but the switches are wobbly as you press them in not guided at all. Not BMW quality hope it works.
Offline Tioli
Re: Tioli mods
« Reply #117 on: July 31, 2020, 01:20:21 PM »
As a refresher on the where I left the bike with a pull through and temporary DRL wiring;
*Originally Posted by Tioli [+]
It's time to put the bike back together but the really and switch for the DRL has not arrived. It's a lot of mucking around taking the crash bar off and it's not one of those things that should be taken on and off all the time.
First is finding a passage from back to front.
It looks clear along the frail rail.
DRL's, connectors and pull through wire
Run the wire from battery box out the right side
The passage is open enough
Over the fuel line I think that is. This will keep it away from the outside of the frame rail there as it's not covered there and would be seen
Up the frame
You won't see that when together
And out it pops near the head stem
I did test pull it through and it worked fine. When the really arrives I just have to attach it and pull through
The DRL attached and how the wire wants to sit which is out of the way
Join the plugs to the DRL
Make up a temporary power surely to the aux power plug
Plugged in
Strangely the power plug fits perfectly in there when not in use. Someone was thinking ahead.
It's dusk at the moment but you can see the DRL's are brighter than the head light DRL and only draw 5w
Offline Tioli
Re: Tioli mods
« Reply #118 on: July 31, 2020, 01:42:39 PM »
Re wired the DRLs to run a wire down to the battery
Taped the DRL and switch wire up and bent round the pull through wire
Bit of a giggle as you pull
And out it comes
« Last Edit: July 31, 2020, 02:32:32 PM by Tioli »
Offline Tioli
Re: Tioli mods
« Reply #119 on: July 31, 2020, 02:21:57 PM »
The instructions are clear enough. I don't know what the top picture is about and yellow black first relay is the bottom switch. For the lights I made earth blue and yellow positive.
The wire for second really I didn't use so isolated
The rest were soldered covered and taped together
It all tuckes away
Power and fuze wire goes back. I changed the 20A fuze for a 5A one as the DRLs are only 5W
Earth wire right round back
Bit of double sided tape on the relay to hold in place and take some vibration out
It workes. When turned on it stays on, lights up as soon as you press the starter, goes out about 20 seconds after the motor is turned off.
Now all I have to remember is turn off when dark.
« Last Edit: July 31, 2020, 02:23:51 PM by Tioli »
