Author [NL] [FR] [ES] [DE] [SE] [IT] [NO] [MY] Topic: Tioli mods  (Read 8064 times)
Re: Tioli mods
« Reply #90 on: June 26, 2020, 12:33:16 PM »
I don't like my centre stand it's to hard so I put a 10mm plate under it and it lifted easier
19mm even easier
Check the clearances
That is just looking to smack your ankle
« Last Edit: June 26, 2020, 12:42:42 PM by Tioli »
Hindsight is a terrible way to learn Id rather be gifted
Re: Tioli mods
« Reply #91 on: June 26, 2020, 01:12:30 PM »
I can see why they put it there it's all to do with the panniers
So I pulled it out and cut a gap out a little over 1cm
It's the only place that works where both sides are evenly vertical
This type of mod crosses skill sets which I never learned Im just a Hack.  So Ved the mating sides deep so the weld penetrates the centre.
I put a tube inside that tube then tapped it home and welded the three together
« Last Edit: June 26, 2020, 02:12:59 PM by Tioli »
Re: Tioli mods
« Reply #92 on: June 26, 2020, 01:37:10 PM »
The bridge between the foot leaver and stand has to come off
Check the cut angle and V it out over half. If your real careful bend it cut again but not as deep bend again and work your way out with the extra cuts and if your lucky it's a close seam.
Not yet
Bingo
Re: Tioli mods
« Reply #93 on: June 26, 2020, 02:03:02 PM »
Weld the bridge back on and check it for clearance
Sits firm on three feet
That is not as high off the ground as I planned and I know where I went wrong.
The pivot point is now near the middle so the height at the pivot point is multiplied out to the wheel at 1.5 or some such ratio.
Ho well I can live with that. I can put it up I can stand there and put it down then put it up and put it down if I did it ten times I would be bored.
Put weight on the rear of the bike and the front comes off the ground so it's functional.
Clean it up, paint you would never know
« Last Edit: June 26, 2020, 02:07:52 PM by Tioli »
Re: Tioli mods
« Reply #94 on: July 03, 2020, 04:39:23 PM »
Now that I have used it for a bit I was thinking I could have done the same by just bringing the foot leaver in like I did but extending it 100mm or more. The extra leverage may be the same as shortening it. At some point it will and it would be interesting to know.
This is more than 50km into a dirt road ride with a 850.
Note the mud splatter on the swing arm and around the shock. You can see some is getting on the shock.
This is the one I made and it's doing its job.
The fork socks are keeping a little off the fork seals. Multiple that out over years and it's worth it.
« Last Edit: July 03, 2020, 04:44:24 PM by Tioli »
Re: Tioli mods
« Reply #95 on: July 10, 2020, 01:41:40 PM »
Now it's time to make the bottom rack. So took the bolt out and cover off then heated the pipe and pressed it on.
Put a rag over it and pressed with my thumb held till it set.
Drilled
For some reason I changed direction and decided to put the cover back on
Got it ready
Re: Tioli mods
« Reply #96 on: July 10, 2020, 01:59:34 PM »
Heat
Bold down to set then take off and heat that area
Massage a down bend
Measur
When I put the right angle bend in it it flared at the sides so clamped the sides back in
Now it's a ridged bend.
Idearly it would be one peice but I'm using up leftovers from the top rack
And adapter peice
Re: Tioli mods
« Reply #97 on: July 10, 2020, 02:17:17 PM »
Because it's a tapered thread I had to heat the joiner nut to make it screw both ends in also heate till soft either side of the joiner so it set in its new happy spot.
Seems to do its job
At this stage I'm prepared to take that on a 3 month ride. Strong, repairable on the fly lightest in the business
The other side I'll just making a weekender till more parts arrive
This one is made from the cheep gardening tube. $6 for 600mm. It handles completely different to the other stuff. The line between soft and melted is really fine. It's far easier to melt and fashion into a new shape.
You can make a right angle bend a flat foot end and all one peice.
Now I wait for the right side long trip part
« Last Edit: July 10, 2020, 02:29:57 PM by Tioli »
Online LFC09
  • Town / City: Sunshine Coast
Re: Tioli mods
« Reply #98 on: July 10, 2020, 11:27:14 PM »
So simple yet ingenious
Re: Tioli mods
« Reply #99 on: July 17, 2020, 03:05:03 PM »
I like the lambs wool seat cover its a good companion warm, softens the seat reduces fatigue however it's not good in the rain left outside overnight and collects dust dirt.
So I'm going to try this cover
It's shaped to fit this specific seat
The idea is it's a 3D mesh. Supposed to be good in hot weather and let air pass under I'm guessing it would be good in the rain
Feels strong enough and bouncy like a mattress
Definitely cooler under seat I will take it off for now as its winter and put back on come summer. Seemed to be as comfortable as the lambs wool will see when I test it more. May be the answer for a 3 month ride.
