I've put an sw motech stand on a low suspension brand new F750GS. Not too bad a job, I supported the bike on a stand under the engine as the sidestand was loose with no problem. The T60 bolt is very very tight. 200nm apparently, it was tough to move.
Biggest bother was getting the left hand plate in position. It has 3 bolts, one of which (#2) has a bit of play, but you can't get bolt #3 on until bolts #1 and #2 are on and you can't tighten #2 when #3 is on. You mount that plate a few times to get it right.
My stand is a heavy lift up and the rear wheel is 3-4" up on the air,but its solid and stable.
