Author Can I use factory 12V power socket for a tire inflator (compressor)?  (Read 3839 times)
  • Offline Sam   us
    • GS Newbie  ‐    1
    Offline Sam
    • GS Newbie
    • Town / City: Long Beach Islan, NJ
    on: Feb 14, 2022, 11.25 pm
    I just bought a dewalt tire inflator.  It doesn't come with a battery or AC cord, but does have a cigarette plug.  Can I use the onboard 12V power socket without risk of blowing a fuse?  Does the engine have to be running?
    -- edit:
    I think the answer is no.  The manual says the socket is rated at 5 amps, and from googling it looks like a little inflator/compressor would potentially draw more than this.
    Last Edit: Feb 14, 2022, 11.31 pm by Sam
  • Offline purds   gb
    • GS Member  ‐    44
    Offline purds
    • Town / City: PETERBOROUGH
    Re: Can I use factory 12V power socket for a tire inflator (compressor)?
    Reply #2 on: Feb 15, 2022, 11.17 am
    Your bike doesn't have fuses - overload protection is provided by the Canbus system which will simply disconnect the power from that circuit. Most mini compressors will draw too much current and power to the socket will indeed be shut down . Best advice is as above - fit a fused flylead direct to the battery to power the compressor. I also us the same flylead for connecting an Optimate conditioner to.
    Last Edit: Feb 15, 2022, 11.18 am by purds
  • Offline Alan R   gb
    • GS Member  ‐    22
    Offline Alan R
    Reply #3 on: Feb 15, 2022, 04.46 pm
    A separate connection to the battery is definitely the way to go. I’ve heard of people test plugging into the onboard socket and watching the compression chug away happily and assuming all will be well when it’s needed to inflate a tyre. However, when under load, pushing anything over about 10psi, the bike canbus will disconnect.
    Alan R
  • Offline richardbd   gb
    • GS Pro  ‐    168
    Reply #4 on: Feb 15, 2022, 09.21 pm
    *Originally Posted by Alan R [+]
    Alan R
    This is the correct answer…
     :0461:
  • Offline ca1ic0cat   us
    • GS Newbie  ‐    8
    Offline ca1ic0cat
    • GS Newbie
    • Bike: F850GSA
    • Town / City: Webster
    Reply #5 on: Feb 19, 2022, 02.28 am
    The other way is to hardwire a fused connector into the battery with a fuse able to handle the mini pump.  That's what I do because I also use a Battery Minder charger.
