Author [NL] [FR] [ES] [DE] [SE] [IT] [NO] [MY] Topic: Denali Sound Bomb one beep!  (Read 768 times)
Offline ollythefrog
  • Town / City: Trevellas
« on: July 31, 2021, 08:31:31 AM »
Hiya
I fitted the above horn to my GSA 850 as per the wiring instructions that came with it using a new Canbus lead.
The old horn is still fitted but disconnected.
The problem I have is that when I use the horn it will only beep once for a very short time (it won't do a prolonged beep, if that makes sense).
I have seen posts that say it should be wired to the old horn but have no idea how to do this and can't find any information.
All ideas gratefully appreciated.
Mark
RiderCamTV
Offline doebag
Re: Denali Sound Bomb one beep!
« Reply #1 on: July 31, 2021, 04:31:45 PM »
My denali soundbomb mini works fine and was a straight swap with the supplied connector lead.
It is possible that yours is drawing too many amps and the canbus is shutting the supply down [ there is no fuse to blow]
Reconect the old horn to confirm this, but I suspect that could be your problem
'Dying a'int much of a living' Outlaw Josey Wales
Offline ollythefrog
« Reply #2 on: August 03, 2021, 09:58:37 AM »
Thanks for the reply.
Any ideas how I can overcome this issue?
I think it looks like I will have to buy the sound bomb mini
Cheers
M
RiderCamTV
Offline RadioFlyer
  • Town / City: Pakenham
« Reply #3 on: August 03, 2021, 01:43:51 PM »
The CAN-bus cannot shut anything down. Chassis electrics are controlled by the ZFE.
Offline doebag
« Reply #4 on: August 03, 2021, 06:13:22 PM »
*Originally Posted by ollythefrog [+]
Cheers
M
You could use the current horn feed to operate a relay, and wire the horn direct from the battery +ve and -ve.
Offline doebag
« Reply #5 on: August 03, 2021, 06:14:30 PM »
*Originally Posted by RadioFlyer [+]
You are correct, but like many I suspect, I use 'canbus' as short hand for modern unfused electrics.
Offline RadioFlyer
« Reply #6 on: August 03, 2021, 06:57:42 PM »
*Originally Posted by doebag [+]
The correct term "ZFE" is shorter!
Offline ollythefrog
« Reply #7 on: August 03, 2021, 10:02:50 PM »
Thank you folks for you help.
M
RiderCamTV
