Author [NL] [FR] [ES] [DE] [SE] [IT] [NO] [MY] Topic: Restarting In Gear  (Read 343 times)
Offline Skinny
  • Town / City: N Ireland
Restarting In Gear
« on: July 18, 2021, 11:09:35 AM »
I came from a Suzuki V Strom 1000 and recently changed to a 2021 F850GS.
Question: If the bike cuts out, say when pulling away from lights and you need to restart, why can it not be restarted in gear whilst pulling in the clutch? I must have got a bit lazy with the throttle as the V Strom has a mechanism to automatically stop it cutting out. Having to move into neutral in the middle of a busy junction can quicken the heart rate. I have had numerous previous BMWs and never experienced this problem.
Re: Restarting In Gear
« Reply #1 on: July 18, 2021, 11:51:22 AM »
Something is wrong... I can restart in gear with the clutch pulled in.
Offline Skinny
« Reply #2 on: July 18, 2021, 12:16:13 PM »
Thanks for the reply.
Hmm..... I wonder then if it is one of these programable things? :187:
« Reply #3 on: July 18, 2021, 01:01:34 PM »
Iíd very much doubt it. Iím a previous long-term Suzuki owner and start/restart with clutch pulled in and in gear out of habit. Iíve never had an issue on any BMW Iíve owned (650/700/800/1000XR/1200RS/1200GS/GSA and more recently 750/850GS). What happens when it cuts out? Is it ignition left on and pressing the ignition button again? And does it attempt to start or do you get nothing?
Online MCMXCIVRS
« Reply #4 on: July 18, 2021, 04:11:34 PM »
Sounds like you have a problem with the clutch switch, either out of adjustment or defective.
Offline Skinny
« Reply #5 on: July 18, 2021, 04:50:40 PM »
*Originally Posted by Matty589 [+]
My brain dump re a possible programable "thing" was on the off chance that there may be some benefit for green-laning or the like. Despite having owned circa 8 GS none of them have ever been off road.
I would do exactly as you now and what i would have done previously....ignition is still live, pull in the clutch and hit the start button. when I do this now the bike doesn't start and you have to find neutral to get it going.
« Reply #6 on: July 18, 2021, 05:19:30 PM »
Yep sounds like a bad clutch switch or wiring... I would follow the wire down to where it plugs into the main harness and make sure it's connected. You would think you would get a message on the TFT... You may have a fault code and not know it.
Offline Skinny
« Reply #7 on: July 18, 2021, 05:28:17 PM »
The bike just had it's first service and I was told that there were no faults showing.
Thanks for all the replies. I will speak to BMW Dealership for their comments.
Offline Skinny
« Reply #8 on: July 18, 2021, 08:21:43 PM »
Well I took the advice and went in to my garage to trace the wire back from the clutch prior to speaking to the dealer.
Low and behold I found a loose connection on a cable running just below the clutch cable right at the lever. As I said earlier the bike had just had its first service and I had asked that they move the hand guards up about a quarter of an inch. Could it be that the dealership in doing this inadvertently disconnected this cable? The answer is .....probably.
I don't believe in recriminations so as long as it is fixed then that is the main thing.
Thanks to everyone for their input well done 850GS.com :305: :047:
« Reply #9 on: July 19, 2021, 12:01:10 AM »
I was just down in the garage and remembered this post... Yes there is a connection right at the switch which you apparently found :046:
